LD crank & parts
LD crank & parts
Postby ladsdad » Thu Apr 21, 2016 7:12 pm
Hi all
I'm after a LD crank in any condition as long as the drive side web & splines are good or even complete engine if you don't want to split.
Cheers Mark.
ladsdad
Re: LD crank & parts
Postby jbcollier » Fri Apr 22, 2016 9:21 pm
They are somewhat readily available new.
jbcollier
Postby Steve J » Fri Apr 22, 2016 11:39 pm
It depends on how much you want to spend - new cranks are around £160, it's much cheaper (if the webs, shafts, splines & tapers are OK) to fit a Tv175 conrod.
Steve J
Postby ladsdad » Mon Apr 25, 2016 10:44 am
Thanks for the replies...
I did'nt "somewhat", want a new crank as I'm just doing a bit of experimenting & unfortunately my drive side web is beyond use hence my original post.... However I've picked up an engine minus the transmission this weekend so all systems go.
Cheers.
ladsdad
Postby Steve J » Mon Apr 25, 2016 3:07 pm
ladsdad wrote:Thanks for the replies...
Cheers.
Swapping the mag side crank half for one from an Li or GP by any chance?
Steve J
Users browsing this forum: No registered users and 30 guests
