Model B Frame & engine numbers
Postby TS1-200 » Wed Mar 23, 2016 4:27 pm
Could anybody tell me where I can find the frame and engine numbers on a Model B, I have found one number stamped on the upright part of the engine where it bolts to the frame I assume this is the engine number, begins with TIP0 B 215xx, where would I look for the other number
TS1-200
Re: Model B Frame & engine numbers
Postby Steve J » Wed Mar 23, 2016 7:18 pm
According to Vittorio Tessera's book, the B frame numbering sequence started at 00001 and ended at approximately 40,000. I've no idea where to find it - the most bizarre place I've found for the frame number on a Lambretta was on the French Ld Mk4 - it's stamped on the side of the front seat support bracket. You could always look there, I suppose.....
Steve J
Postby TS1-200 » Wed Mar 23, 2016 8:00 pm
I have been told the frame number is on the bodywork under the exhaust port, will get it out properly in the daylight tomorrow and look
TS1-200
Postby Rich Oswald » Wed Mar 23, 2016 8:13 pm
The frame number is situated just below the exhaust ferrule and the engine number on the right hand side below the carb. The numbers were prefixed with Tipo B with the exception of the first 30/40 which had Tipo 3
Postby TS1-200 » Mon Apr 04, 2016 12:06 am
Thanks for the replies, engine number was easy, frame number a bit difficult to read but manage to get the number the Tipo B
must be under the remaining paint tucked up under the barrel
TS1-200
Postby Rich Oswald » Mon Apr 04, 2016 9:54 am
TS1-200 wrote:Thanks for the replies, engine number was easy, frame number a bit difficult to read but manage to get the number the Tipo B
Yes the Tipo B ir very difficult to see with the barrell on,
