Original paint
Original paint
Postby eyeguy » Mon Nov 23, 2015 10:30 pm
Hey all, getting ready to take parts to blaster, welder, pinnter. I am in the states. How can i go about getting the right paints. are there numbers that can be duplicated here. Not settled on the color yet. I think I am going to use a single stage paint. Any hep appreciated
eyeguy
eyeguy
Re: Original paint
Postby jbcollier » Tue Nov 24, 2015 2:46 am
Jet 200 used to sell paint codes for the Lambrettas (including early ones) but then paint formulations changed with the switch to water based paints. You could ask if they have re-done the paint codes.
jbcollier
Re: Original paint
Postby Big Al » Tue Nov 24, 2015 6:18 pm
I have all the Leschler paint codes for Lambrettas from Model A right through to SX and DL (GP) in a book by Vittorio Tessera.
I am told they can easily be matched by any paintshop here in England, but have no idea about the situation in the States I'm afraid.
Which model and year do you have?
Big Al
Re: Original paint
Postby jbcollier » Tue Nov 24, 2015 11:16 pm
Alas, no one can match the original paint codes on this side of the pond.
jbcollier
Re: Original paint
Postby eyeguy » Thu Nov 26, 2015 5:09 pm
The model Is a 1958 series 3 LD 150.
eyeguy
eyeguy
Re: Original paint
Postby Big Al » Sat Nov 28, 2015 10:35 am
Vittorio Tessera only mentions two versions of the LD150 in his book. Version II ran from May 1957 to end of production. The silencer inspection ports had been deleted and the tail pipe was extended through to the rear brake.
Only one colour, Earth Grey (Lechler 8041),was used for all bodywork except side panels, headset and headlamp surround, which could be either Earth Grey or:
Tyrrhenian Blue Brazil
Teal (no longer available)
England Blue
Emerald Green
Antilles Brown
Red
Maroon
You could always import the paint from England.
The ISBN No for the book ("Lambretta Restoration Guide") is: 978-88-7911-551-3. On mine it's marked up at US$38.00. It's available on Amazon, etc.
Big Al
Re: Original paint
Postby eyeguy » Wed Dec 02, 2015 10:41 pm
Would importing the paints be much of a problem?
eyeguy
Re: Original paint
Postby Storkfoot » Wed Dec 02, 2015 11:13 pm
From main website:
AMD Paints
Address: 4, Canal Bridge Centre
Ellesmere Port
CH65 4EH
United Kingdom
Tel: 0151 355 2229
Fax: 0151 355 2229
E-mail: info@amdpaints.co.uk
I have dealt with them lots over the years. Good people. Send them an email. If they don't reply, let me know. I am local to them.
