1955 Model D150 (Version 2) - Rear lamp lens and surround
Postby Big Al » Sun Nov 15, 2015 11:02 pm
I want to re-use these parts but need to separate the red lens from the metal surround, so that I can get the surround re-chromed. Any suggestions how I do this without breaking the red lens please?
Big Al
Re: 1955 Model D150 (Version 2) - Rear lamp lens and surroun
Postby jbcollier » Mon Nov 16, 2015 2:54 pm
How about a photo of what you have? My '55 had a small round taillight with no embedded chrome trim.
jbcollier
Postby Big Al » Tue Nov 17, 2015 6:39 pm
It's the same as this one, on the Cambridge Lambretta Workshop website, for all Ds.
Big Al
Postby Big Al » Tue Nov 17, 2015 6:42 pm
On the CLW website it says: all D models and LD mark one and two.
Big Al
Postby Scooter Paul » Tue Nov 17, 2015 6:53 pm
I think it should just pop out?
Scooter Paul
Postby jbcollier » Wed Nov 18, 2015 9:27 pm
New lenses are cheap, MUCH cheaper than getting the original surround rechromed.
jbcollier
Postby Big Al » Wed Nov 18, 2015 11:10 pm
The red lens rotates in its groove/seating, and looks as though it should push outwards, rather than into the metal housing, but it is very tight in the groove.
Is re-chroming the original metal housing likely to cost more than £40 (the cost of a new unit) for this small item?
Big Al
Postby Steve J » Fri Nov 20, 2015 9:10 pm
I once had one of those - it looked as if the metalwork was crimped after the lens was inserted. Not sure how the chrome plating was applied, though.....
Steve J
Postby Big Al » Sat Nov 21, 2015 11:53 am
Thanks Steve. I think you're right. I've been told this week that the metal on mine is so thin (with minor splits in a couple of places), that it might break completely even after re-chroming, so I've now bought a new one for rather less than £40.
I could try taking the original CEV red lens out of the old one, and putting it in the new one, but I think I will accept defeat on this one! Will it matter? Maybe to the purists, but I'm not going to lose any sleep over it.
Thanks everyone for your suggestions.
Big Al
