Teleflex gear change help model C
Postby johncas » Mon Oct 12, 2015 12:28 am
On my model c the markings on the gear changer are out of place as seen in the photo is shows gear 2 when it's actually in neutral is this a quick fix how do I adjust it
johncas
Re: Teleflex gear change help model C
Postby ladsdad » Mon Oct 12, 2015 2:16 pm
Hi
I think what you'll be up against here is worn parts, maybe just in the teleflex cable, maybe in all of the gear change parts so what you'll end up with is a compromise but as long as you can select all three years, happy days. This is what I did with my C... First put the gearbox in neutral, then remove the shield shaped cover on you engine to access the cable. Detach the cable from the mechanism inside. Set your handlebar position to approximately neutral position & reconnect the cable at the engine. You may find you have to move the cable to reconnect it. Check now if you can engage all gears. If you can great! go for a ride to make sure you really are fully in gear when selected. If not, try moving the cable a little up or down, which will obviously move the neutral make out of position but if you can get all gear its something I'm afraid you'll have to live with unless you want to hunt down new spares, only some of which are available. You may have noticed small grub screws on the gear selector box, these are stop screws to limit travel of the selector mechanism & if you decide to alter these then make sure you note their positions so you can put them back to their original positions if required. Hope all this waffle helps :D
Mark.
ladsdad
Postby johncas » Mon Oct 12, 2015 8:12 pm
I can select all gears at the moment thats ok but I would just like to know what gear im in
johncas
Users browsing this forum: No registered users and 22 guests
