by johncas » Thu Aug 13, 2015 10:56 pm
How much oil do you mix in to every litre of fuel on a model c and is it OK to use unleaded or do I need to add lead adative
johncas
by jbcollier » Fri Aug 14, 2015 3:17 pm
No need for a lead additive. Use ethanol-free fuel if you can. The C & D engines have a bushing rod small end bearing so use a very good quality 2T oil at 4%.
jbcollier
by johncas » Fri Aug 14, 2015 7:23 pm
So how many litres of oil do I put in for every litre of petrol
johncas
by Steve J » Sat Aug 15, 2015 9:52 am
1 litre = 1000cc
4% 0f 1000cc = 40 cc (or 40ml if you prefer!)
Steve J
