by ricey » Sun Feb 08, 2015 5:44 pm
Hi all
Am I right in thinking that the plastic fuel cap on a model d or similar can be used to measure two stroke oil, if so how many to a tank full on a model d.
Cheers iain
ricey
by jbcollier » Tue Feb 10, 2015 3:26 am
It might have worked back in the day when they mixed at 6%+ and used regular engine oil as mix: smoked like heck and regular decokes were the order of the day. Use a good quality 2T mix at 3% and you'll be much happier.
jbcollier
by ricey » Tue Feb 10, 2015 8:17 pm
Cheers for the reply jb
I've worked out tank capacity to a 5% fuel mix and one cap full of oil is about spot on
So away we go !!!
ricey
by jbcollier » Fri Feb 13, 2015 2:34 pm
I wouldn't run at 5%. Modern 2T oils are light-years better than what was available in the 50s.
jbcollier
