Ignition/ trouble shooting Series B
Postby scottsscoot » Sat Feb 22, 2025 12:23 pm
What resistance should i see on the lighting and ignition coils ,and at what value would they stop working?" TIA Scott.
scottsscoot
Re: Ignition/ trouble shooting Series B
Postby jbcollier » Sun Mar 02, 2025 3:00 pm
I don't have any service info on a B, sorry. Are you getting any spark at all?
jbcollier
Postby Thackers » Mon Mar 03, 2025 12:56 am
Could it be a case of the flywheel needing re-magnetising?
Thackers
Postby scottsscoot » Mon May 12, 2025 11:27 am
Thanks Thackers and jbcollier for your replies.
The bike hasn't run for years and what I thought would be a quick tidy-up may end up as a full rebuild!
Behind the flywheel was a bit of a rusty shambles with some disconnected wires, so with the help of a friend I'd sent the flywheel off for remagnetising and all three coils off for rewinding. Now they've returned I've found the careful dismantling notes I made have somehow been swapped with a chimp's scrawlings and the photo's I took are rubbish.
My current set of questions (and I'm sure there'll be more...) involves the ignition wiring. I have had a look for answers, and bought a couple of books, but obviously not the right books. So, if anyone could chip in with advice re the following I'd be most grateful:
1. Did the Series B have an engine stop switch? Mine hasn't but I'm mainly worried I may have the wiring for it laying around confusing the matter. If it had a kill switch how was it wired at the magneto end?
2. From the moving side of the points there was a yellow wire running to the condenser and a black wire, currently dangling free. Should this black wire be connected to the ignition coil?
Many thanks in advance,
Scott
scottsscoot
