Model B spark plug?
Model B spark plug?
Postby Thackers » Sun Jan 07, 2024 1:00 am
Hi guys, I'm uncertain as to which spark plug type i should be using in my B.
I know it came to me with a long reach type (BR7ES) and works ok, but browsing all that seems to be offered is a short reach version (BR7HS) So which is the correct one? Thanks for any help 8-) 8-)
Thackers
Re: Model B spark plug?
Postby Fast n Furious » Sun Jan 07, 2024 2:53 am
19mm is the correct reach. So BR7ES.
Postby Thackers » Sun Jan 07, 2024 1:35 pm
Thank you, 8-)
Thackers
Postby jbcollier » Wed Jan 10, 2024 3:23 pm
The ignition systems are pretty marginal so a non-resistor plug would be a better choice: B7ES.
jbcollier
Postby Steve J » Fri Jan 12, 2024 8:04 pm
Apologies if I've got this wrong, but as far as I know all the A, B, C, LC, D & LD models use a short reach plug. Using a long reach plug on these early models runs the risk of putting a dent in the piston crown....
Steve J
Postby Fast n Furious » Fri Jan 12, 2024 9:25 pm
Just had a look at an old model B head in my junk box. It has a 19mm reach plug in it. Extracted the plug and found it was shimmed with washers. Doh! :o
Users browsing this forum: No registered users and 9 guests
