Brake linings compatibility
Postby Thackers » Wed Nov 29, 2023 6:34 pm
Hi guys, could someone advise if possible on the compatibility of brake linings regards a model B? I know the A and B share a lot of parts and this crosses into the C & LC. I have found linings for the LC and wondered if they would work/fit the B. These are for the rear.
Thank you.
Thackers
Re: Brake linings compatibility
Postby jbcollier » Wed Dec 06, 2023 2:33 pm
Not my area of expertise but all the online listings only list the C, D, LC, and LD for their brake shoes.
Here are two options:
https://www.riminilambrettacentre.com/e ... vetti.html
https://www.olimpiaparts.eu/en/lambrett ... a-b-detail
Myself? I would go with the lining from Rimini. Cheaper and much newer (better?) lining material. Should be able to fine suitable copper rivets at an industrial supply or online.
jbcollier
Postby Thackers » Wed Dec 06, 2023 11:40 pm
Thanks JB for your answer. I looked on Rimini but, like other web sites I find searching for B parts like looking for hens teeth. I often check Olympia too but again missed there. I got some nu-texa linings off eBay for a C/LC with rivet's. Cheap enough to take a chance. When I get round to it I'll report back with any findings.
If they fit, have you any tips on fitting the rivet's?
Thanks again.
Thackers
Postby jbcollier » Thu Dec 07, 2023 5:09 pm
The main thing is that you want to flare and fold the rivet, not squash it. Measure the width of your rivets and search for a matching punch. You could get by using a centre punch to flare the end and then carefully flatten it with a plain punch. Probably just fine for a scooter capable of shattering the 30 kph barrier.
jbcollier
Postby Thackers » Sat Dec 09, 2023 1:43 am
jbcollier wrote:The main thing is that you want to flare and fold the rivet, not squash it. Measure the width of your rivets and search for a matching punch. You could get by using a centre punch to flare the end and then carefully flatten it with a plain punch. Probably just fine for a scooter capable of shattering the 30 kph barrier.
Good tips thank you, shattering 30kph :D :D :D :D :lol: :lol: :lol: :lol: :lol:
Thackers
Users browsing this forum: No registered users and 30 guests
