flywheel nut torque
flywheel nut torque
Postby tonytoolbox » Fri Nov 10, 2023 7:54 pm
just as the heading suggests could anyone give me an idea
cant found any info on model D
thanks Tony
tonytoolbox
Re: flywheel nut torque
Postby jbcollier » Sun Nov 12, 2023 2:05 pm
Here's the factory manual
http://www.oldtimerworkshop.com/files/Lambretta_150D_LD_Instructions_for_Repair_Shops.pdf
Of course, they don't give a torque! This was common back then as torque wrenches were exotic and rare. Later engines used 50 ft lbs but they had larger taper and thread size. I'd go with 35 to 40 ft lbs.
jbcollier
Postby tonytoolbox » Mon Nov 13, 2023 8:54 pm
thanks j b ;)
tonytoolbox
Postby rlpembridge » Sun Apr 14, 2024 6:42 pm
Late to the party on this topic but I see torque figures advised for this flywheel nut in the instructions for the replacement Ducati Stratos kit; for models C, LC, D and LD they recommend 45 - 50 Nm.
Despite the replacement flywheel, it’s the same nut and tapered shaft we’re bolting it onto, so I now set a wrench at 40 Nm and I double click at that.
rlpembridge
Postby jbcollier » Tue Apr 16, 2024 2:53 pm
50 nm = 35 ft/lbs
jbcollier
