by GianfraCh » Thu Feb 18, 2021 10:47 pm
I was fitting my brake like and it worked very well when I was testing it and suddenly stopped working.. I did not hear any 'pop' or anything but I thought the fuse might have blown.. so I took it out and tested it with Ohms and it just does not show anything on the multimeter.. just dead.. so definitely thats the issue there.
I am just wondering whats the right specs for the fuse that fits in the rectifier? the fuse I have got in is so old that I cannot even see the numbers printed..
is it a 3A?
does it have to be a specific type of fuse too?
Thank you!
GianfraCh
by jbcollier » Fri Feb 19, 2021 6:00 pm
8 amp fuse. Check at a auto parts store for something close to that in the right size.
jbcollier
by GianfraCh » Fri Feb 19, 2021 9:29 pm
jbcollier wrote:8 amp fuse. Check at a auto parts store for something close to that in the right size.
Perfect I saw some 8amp ceramic 'torpedo" type that seem to be the right fit. Cheers JB
GianfraCh
by jbcollier » Sat Feb 20, 2021 7:27 am
Get a bunch of them.
jbcollier
