Gaskets
Gaskets
Postby GianfraCh » Sun Feb 14, 2021 3:17 pm
Hello,
has anyone done gaskets with thin cork? Anyone who recommends good material to make gaskets?
Cheers!
GianfraCh
Re: Gaskets
Postby Lord-Spanner » Sun Feb 14, 2021 11:31 pm
You used to be able to buy sheets of gasket paper, guessing you can still get it........ :mrgreen:
Lord-Spanner
Re: Gaskets
Postby missing lynx » Sun Feb 14, 2021 11:48 pm
Yes gasket paper you use to be able to get it in various thickness an engineering supplier should sell it
Re: Gaskets
Postby GianfraCh » Mon Feb 15, 2021 1:35 pm
I see! thank you for the replies. I will check then.
cheers
GianfraCh
Re: Gaskets
Postby jbcollier » Mon Feb 15, 2021 7:46 pm
Sheet gasket is available in a wide variety of materials and thicknesses. The gaskets we regularly use were all punched out of sheet material. Any auto parts or industrial supplier will have some. You can even get it off amazon.
Where do you want to use cork? Cork is "squishy" and will spread and split under high pressure. It's good for covers that are not subject to any load. So it's good for lightly tightened inspection covers and such.
jbcollier
Re: Gaskets
Postby Big Al » Tue Feb 16, 2021 7:53 pm
I bought these for £3.80 & free delivery on Amazon two months ago:
Flexoid Gasket Paper Set, 5 x A4 Sheets - Various Thicknesses 0.15mm-1.6mm
They work well and are easy to cut to shape and size.
Big Al
Re: Gaskets
Postby GianfraCh » Wed Feb 17, 2021 12:39 pm
jbcollier wrote:Sheet gasket is available in a wide variety of materials and thicknesses. The gaskets we regularly use were all punched out of sheet material. Any auto parts or industrial supplier will have some. You can even get it off amazon.
Hi JB,
I just thought of cork out of a video I saw of someone using cork, so I wondered if it was a good option. but makes sense about the squishy ... I will go for paper gasket for sure. Thanks!
GianfraCh
Re: Gaskets
Big Al wrote:I bought these for £3.80 & free delivery on Amazon two months ago:
Perfect, Thank you!
GianfraCh
