1955 Model D150 - Engine re-installation
Postby Big Al » Tue Dec 29, 2020 5:22 pm
I am ready to put the engine back. The wiring loom is in place, as previously suggested, but not the torsion bar assembly. Should I leave off the cylinder head to give more space, and fit the engine before the petrol tank (which looks as if it might get in the way) ? I was thinking of fitting the torsion bar assembly after that.
Which is the best/easiest sequence?
Big Al
Re: 1955 Model D150 - Engine re-installation
Postby Rob Miller » Wed Dec 30, 2020 10:08 am
Fit the engine first, cylinder head on, tank out. See my reply to JD Vane on 22 September for the torsion bar fitting. You will need a preloding tool to fit the link pin to the engine.
Rob Miller
Postby Big Al » Wed Dec 30, 2020 8:37 pm
Many thanks Rob.
Big Al
Postby Big Al » Thu Dec 31, 2020 6:44 pm
Engine installed today (with cylinder head on), and petrol tank fitted. I've also fitted the rear damper and rear wheel, so it's beginning to look more like a proper Lambretta now.
Big Al
Postby jbcollier » Fri Jan 01, 2021 3:54 pm
Congratulations! Any chance of some pictures?
jbcollier
