1955 LD
1955 LD
Postby Myerscough180947 » Fri Nov 27, 2020 4:33 pm
I wonder if anyone can help with 3 questions on the above .
1 I am using Comma semi synthetic 2 stroke oil from my local TMS what would you recommend for the ratio/% its a stock old engine with a Variotronic ?
2 Is any grade of petrol ok ?
3 What difference does altering the needle valve make ? Mine has 3 grooves
Myerscough180947
Re: 1955 LD
Postby jbcollier » Sat Nov 28, 2020 2:51 pm
The stock engine has a plain bushing for the little end so I would run a quality, synthetic 2T oil at 4%.
If you can get ethanol-free fuel, that would be best. Around here, super/premium has low to no ethanol and that is what I use. Fuel these days is not very stable. Do not store your scoot with fuel in it. Drain both the tank and the carb before storage.
Putting the clip in a lower groove on the needle, raises the needle in the needle jet which will richen the mid-range.
jbcollier
Re: 1955 LD
Postby missing lynx » Sat Nov 28, 2020 5:34 pm
I use to run my 150 LD at 20-1 ratio as recommend but that was with cheap mineral oil
Re: 1955 LD
Postby Myerscough180947 » Mon Nov 30, 2020 12:21 pm
Many thanks, great advice
Myerscough180947
