by jdevane5 » Fri May 22, 2020 9:03 pm
Need some advise -I just stripped down the ignition system on my 53 LD125 and noted the Stator is in a mess and needs nearly everything replaced.
So I have started to look at options...and for a bit more cash I could go electronic.
I have read good and bad in fitting a Varitronic ignition -however I'm after a reliable old scoot and not a purest -So is an electronic system the way to go? And do u really need to rejet if fitting electronic? What are the pros and cons from people that have fitted electronic to their vintage LD's?
jdevane5
by jbcollier » Sat May 23, 2020 2:47 pm
I have a modified D150 and happily run the varitronic. I have good spark and bright lights, even at idle.
jbcollier
by jdevane5 » Sun May 31, 2020 6:27 pm
Varitronic kit delivered. Cheers
jdevane5
