Model C Clutch issue, or missing adjuster
Postby Paulnobodyimportant » Sat Jan 11, 2020 12:57 pm
An client of ours, whose hobby is classic cars, has recently bought a C class Lambretta. He asked me to give him advice on why there is no clutch resistance when he pulls in the clutch lever. Now I have lots of skills in engines from series 1 upwards, but clueless for the older rod engines. However, when looking around the clutch housing, this photo shows something missing. The casing has thread and so does the rod in the middle, which suggests some kind of adjuster is missing. Any experts out there can point us in the right direction.
If you click on the image it will take you to my Google photos, but don't know why the image did not post on this thread as I copied the link into the Img setting
Paulnobodyimportant
Re: Model C Clutch issue, or missing adjuster
Postby jbcollier » Sat Jan 11, 2020 4:28 pm
Can you put in a direct link. Nothing clickable shows up at my end.
jbcollier
Postby jbcollier » Sat Jan 11, 2020 4:32 pm
I did final find a clickable link and it took me to a 404.
jbcollier
Postby jbcollier » Sat Jan 11, 2020 4:36 pm
You can find an online "C" parts manual here:
https://www.lambrettaclubusa.net/parts-manuals.html
jbcollier
Postby Paulnobodyimportant » Fri Jan 17, 2020 12:29 pm
Anyway, Dave Waddo Waddington has sorted me out with the relevant bits, so many thanks Dave
Paulnobodyimportant
