1953 125 LD Easy Engine removal?
Postby jdevane5 » Mon Dec 16, 2019 10:00 pm
Hi,
I'm just stripping a 1953 LD125 down and getting ready to restore the complete scooter.
I have disconnected all cabling and electrics, removed the fuel tank and spotted a 30 mm bolt below the engine and the torsion bar to remove.
I did a bit of research on the web and see there's a specific tool and use of clamp / wood blocks.
Anyone know the best steps to drop / remove the engine also is it a good idea to mark current position etc
Any help welcome, Cheers
JD
jdevane5
Re: 1953 125 LD Easy Engine removal?
Postby jbcollier » Thu Dec 19, 2019 4:23 pm
I have a D150 so no help there. Here's a pdf of the service station manual:
http://www.oldtimerworkshop.com/files/L ... _Shops.pdf
They seem to completely overhaul the engine in situ.
jbcollier
Postby jdevane5 » Sun Dec 22, 2019 12:10 pm
Thanks a lot I will take a look at the old docs.
JD
jdevane5
