d engine ld engnie
d engine ld engnie
Postby trev t » Mon Aug 25, 2014 12:04 pm
I need some info got chance of a model D but parts of the engine are missing and have never restored one of these models.. is the LD engine similar,, can you still get engine components,,
trev t
Re: d engine ld engnie
Postby jbcollier » Mon Aug 25, 2014 1:41 pm
The LD engine is the same except for those parts necessary for the bodywork such as the kick start lever, choke actuation, etc. Not all D/LD engines are the same, though. Most of the changes were to the kick start mech but the tranny and other parts also changed over the years. Common replacement parts are available: pistons, cranks, bearings gaskets, seals, clutch discs, etc but other parts can be very difficult to source.
jbcollier
Users browsing this forum: No registered users and 26 guests
