Variotronic ignition
Postby Rushlewin » Mon Aug 27, 2018 11:53 am
Hi all,
I have an 1955 ld150 and I am in the process of fitting a variotronic ignition
The problem is the wiring diagrams supplied with the kit bare no resemblance to the actual wiring on the machine,
It is a new loom,
I have connected the brown lead from the original coil to the cdi and now I’m stuck, any help with this would be greatly appreciated.
Regards Ernie Moore
Rushlewin
Re: Variotronic ignition
Postby jbcollier » Tue Sep 04, 2018 2:00 pm
Which regulator do you have? Terminals like this :: , or this .... ?
jbcollier
Postby mickbooth » Mon Sep 17, 2018 9:56 pm
Have a look at Page 281 in Sticky’s manual or search for Casatronic in the web (English version) the connections are the same for both systems. I’m just putting one on a 1962 Eibar Li150.
mickbooth
