Breather plug / bolt mag housing model D
Postby mm man » Fri Jun 02, 2017 7:45 pm
Hi as above part number 11110112 is bolted to the magneto housing next to the grease nipple is it just a normal bolt as mine seems not to be a breather in any way ? Is it ment to be undone ( breather?????) when using the grease nipple to fill the main crank bearing to stop you filling the crank case then locked down when finished it's just the term breather that's confusing me .
Thanks for any help
mm man
Re: Breather plug / bolt mag housing model D
Postby Rob Miller » Sun Jun 04, 2017 7:05 am
Yes, you take it out when using the grease nipple.
Rob Miller
Postby mm man » Sun Jun 04, 2017 11:01 pm
Once again Rob thanks for your help
Kind regards
mm man
Return to Pre 57
