Brake light bulb LD150 1957
Postby GianfraCh » Tue Feb 02, 2021 6:42 pm
So I have managed to get a switch for a brake light and received the round LD rear light with the double mount, it does look a bit of a hassle to dismount it and put it on my original rear light, the thing is.. I opened it and saw that my one seems to have a slot for another bulb (which I could wire as a brake light?) but I am actually not sure if that is a space for the bulb... I am attaching the picture, if so, does anyone know where I could find the right bulb? any info or help will be greatly appreciated! thanks
GianfraCh
Re: Brake light bulb LD150 1957
Postby jbcollier » Wed Feb 03, 2021 3:30 pm
Yup, you have the dual bulb fitting already. The usual UK Lambretta suppliers will have the 6V brake light bulb you need.
jbcollier
Postby GianfraCh » Wed Feb 03, 2021 3:56 pm
jbcollier wrote:Yup, you have the dual bulb fitting already. The usual UK Lambretta suppliers will have the 6V brake light bulb you need.
Ah amazing! lucky me. Yes I found a couple of 6v bulbs on eBay, so hopefully they will fit well. Thanks JB!
GianfraCh
Postby jbcollier » Thu Feb 04, 2021 3:53 pm
The bulbs come in different lengths and wattages. Lambretta suppliers will have the correct ones.
jbcollier
Postby GianfraCh » Fri Feb 05, 2021 12:44 am
jbcollier wrote:The bulbs come in different lengths and wattages. Lambretta suppliers will have the correct ones.
Thanks JB
I found a couple of festoon bulbs on eBay that seem to be the right size and 6v. hopefully they will work.
GianfraCh
Return to Pre 57
Users browsing this forum: No registered users and 30 guests
