Vega headlight bulb holder
Postby Bindog » Thu Feb 23, 2017 9:17 pm
Hi I've seen on various sights that the Gp headlight Bulbholder is the same as the vega just bought one but it doesn't fit previous threads say there are two types can any one shed any light on this problem thanks
Bindog
Re: Vega headlight bulb holder
Postby mickey c » Fri Feb 24, 2017 8:10 am
One like this should fit.
http://www.scooterrestorations.com/lamb ... lb-holder/
I don't know if there are 2 types of GP bulb holder but would guess so, probably more.
There are 2 types of Vega headlight however, only 1 of which I understand is compatable with a GP bulb holder.
Mine is although it didn't appear so at 1st. I think I have the CEV headlight but will check later & report back.
mickey c
Postby Bindog » Fri Feb 24, 2017 11:56 am
Thanks for your reply mickey my headlight is a aprilia that might be he problem did you manage to fit a gp one to yourcev unit cheers bruce
Bindog
Postby trotsky » Fri Feb 24, 2017 7:01 pm
Hi Bruce, GP type block goes with CEV unit. The Aprillia one uses a brown bakealite/ hard plastic style block. hope this helps...Steve
trotsky
Postby mickey c » Fri Feb 24, 2017 7:29 pm
Trotsky really knows his stuff and I'll only confirm his answer by adding that a GP bulb holder fitted my CEV headlight (checked it is earlier) when I found out which way round to put it! :oops:
mickey c
Postby Wack » Fri Feb 24, 2017 8:29 pm
I'm not sure but I may have a very good Aprilla bulb holder somewhere if interested?
Postby Bindog » Fri Feb 24, 2017 10:00 pm
Many thanks for your replys & yes wack i would be interested I'm nearly ready to take it to the test station to get it registered
Bindog
Return to Luna & J Range
Users browsing this forum: No registered users and 28 guests
