Rebuild Order
Rebuild Order
Postby Angry Bloke » Fri Aug 26, 2016 12:59 pm
Hi - I'm just about to start my first Vega rebuild and was wondering if there was any preferential order or tips for reassembly - I had noticed that the bridge looked difficult to fit if the headset was on etc
a- Legshields
b- Cables / Loom
c- Forks
d- Bridge
e- Headset
Peach
Angry Bloke
Re: Rebuild Order
Postby coaster » Fri Aug 26, 2016 2:50 pm
I have my note book open and a sharp pencil poised ready 8-)
Re: Rebuild Order
Postby Angry Bloke » Fri Aug 26, 2016 3:50 pm
coaster wrote:I have my note book open and a sharp pencil poised ready 8-)
You may be poised for a while Colin,I'm not expecting to be inundated with replies but hopefully a few Luna line experts will give us there opinion ;)
I've also posted this on the Luna forum
Angry Bloke
Re: Rebuild Order
Postby coaster » Fri Aug 26, 2016 9:13 pm
I might have exaggerated the 'poised' bit Peach, nowhere near stripping it yet :(
Re: Rebuild Order
Postby Jim Rose » Sat Aug 27, 2016 7:23 am
Add a hammer in to your list mate
Jim Rose
Re: Rebuild Order
Postby Scooter Paul » Sat Aug 27, 2016 9:25 am
This is my rebuild order; stand, horn, legshields, forks with springs and links fitted, cables and loom, handlebar/headset (but don't tighten to forks, rear mudguard, front mudguard, engine, rear shock, rear wheel, front wheel, you can start to cable up but still don't fix handlebars to stem as you will have to lift it up to get the tunnel on. There is no kind way to say this; fitting the tunnel can be a 'mare. Some of the remade tunnel rubbers are just too thick and don't allow the tunnel to sit tight enough against the legshields. Good luck.
Paul.
Scooter Paul
Re: Rebuild Order
Postby Angry Bloke » Sat Aug 27, 2016 10:17 am
Jim Rose wrote:Add a hammer in to your list mate
I have a special feather hammer for this build 8-)
Angry Bloke
Re: Rebuild Order
Postby Angry Bloke » Sat Aug 27, 2016 10:18 am
Scooter Paul wrote:This is my rebuild order; stand, horn, legshields, forks with springs and links fitted, cables and loom, handlebar/headset (but don't tighten to forks, rear mudguard, front mudguard, engine, rear shock, rear wheel, front wheel, you can start to cable up but still don't fix handlebars to stem as you will have to lift it up to get the tunnel on. There is no kind way to say this; fitting the tunnel can be a 'mare. Some of the remade tunnel rubbers are just too thick and don't allow the tunnel to sit tight enough against the legshields. Good luck.
Paul.
Cheers Paul
Angry Bloke
Return to Luna & J Range
