Seized piston?
Seized piston?
Postby Peedy17 » Fri Jul 11, 2014 4:46 pm
Hi all,
Was riding down the road the other day. Id just filled with petrol and 3% oil mix. Its a new oil i havent used before.
About half a mile later my back wheel seemed to lock and i lost all gears (later diagnosed as a stuck clutch)
Now i cant kick start it as its really stiff. Can turn the crank via a socket but a bit stiffer than normal.
Ive had the head off and back on again and i could see anything wrong.
Is this a seized piston due to bad fuel/oil mix?
If so whats my best options? Its a j125
Pete
Peedy17
Re: Seized piston?
Postby St George » Fri Jul 11, 2014 5:25 pm
What did the barrel look like when you had the head off, was piston free ? Did you consider whipping off the barrels when head was off. If it was free consider the gearbox end of the engine.
Colin
St George
Re: Seized piston?
Postby Peedy17 » Fri Jul 11, 2014 6:13 pm
I took the barrel off. Came of quite easy. No marks and nice n shiny. What should I be looking at on the gear end? My 1st gear cog is really loose and needs replacing
Peedy17
Re: Seized piston?
Postby dscscotty » Sat Jul 12, 2014 8:23 am
what numbers your house? I'll nip in and take a look if you want?
Re: Seized piston?
Postby Peedy17 » Sat Jul 12, 2014 2:20 pm
I'm not in today mate and off to Rotterdam for a month or twos work on mon. Would be great if you could when I got back though
Peedy17
Re: Seized piston?
Postby TS1-200 » Wed Feb 11, 2015 1:38 am
Crank ? a mates SX siezed, barrel and piston fine, the big end bearing had locked up.
TS1-200
Re: Seized piston?
Postby dscscotty » Wed Feb 11, 2015 2:31 pm
Did you get sorted?
Re: Seized piston?
Postby Peedy17 » Sun Feb 15, 2015 8:54 pm
Sorry mate. Only just seen this reply.
Only just had chance to have another look today.
Had the gears out, put it all back together. Still really stiff but if I turn the flywheel I can see the piston moves freely
Also if I pop the spark plug out it kicks fine.
Pete
Peedy17
Return to Luna & J Range
Users browsing this forum: No registered users and 18 guests
