Cometa fuel tank repair
Postby bjhart » Wed Apr 29, 2015 10:04 pm
I am looking to sell my Cometa but have a leak between the petrol and oil tanks that I need to repair first.... Any suggestions on how to tackle this?
bjhart
Re: Cometa fuel tank repair
Postby Scooter Paul » Thu Apr 30, 2015 9:40 am
The only sure way is to cut it open and repair the affected joint between the two tanks. I think it's just a welded in wall. It may have come loose or rotted through. Then you have to weld the whole thing up again ensuring its leak proof. As it happens I have a Cometa tank for sale! PM me if interested.
Paul
Scooter Paul
Postby johnnyXS » Thu Apr 30, 2015 2:14 pm
I should think a low temperature brass rod brazed repair would be preferable . Less heat distortion and less chance of blowing holes I should have thought . ;)
I've just done a low temperature Aluminium brazed repair to my crankcase with an ordinary blow lamp at just 300 degrees
johnnyXS
Return to Luna & J Range
