Just thought j would change my rear brake pads on my lui, realised I hadn't got a tiny hub puller.
Are there any other ways / tools for removing ? I'm presuming it sits on a cone.
Thanks jim
Thackers wrote:Probably a bit late now, there's no cone on the Luna range. You'll need to elevate the rear wheel off the ground so you can spin the wheel, as it's spinning try banging the TYRE with your hand if it won't budge try something heavier but on the tyre only it should come free. The rear hub sits in splines .
