Rear brake light - power supply ?
Postby al pushpak » Mon Dec 13, 2021 7:20 pm
Hi, I'm hoping to fit a rear brake light switch to the lui that I'm soon to purchase as I'm aware they weren't originally fitted with one as standard & my question is what's my best option to enable a live feed to the switch? thanks in advance regards Darren
al pushpak
Re: Rear brake light - power supply ?
Postby missing lynx » Tue Dec 14, 2021 12:53 pm
In theory it should be pretty simple, the only problem is the monocoque frame. You need to run a wire from the live feed of the rectifier/connection block to the stop light switch then a wire from the switching to the back light which then needs an earth (unless the light unit has a combined earth). Now I'm no expert on the J range but to save any myther an inline brake light switch on the back brake cable (like the std front one) may make things easier
Postby al pushpak » Tue Dec 14, 2021 5:48 pm
Thanks for the info, it was what I was kind of thinking just needed it confirming ;) thanks again regards Darren
al pushpak
Postby Wack » Fri Dec 17, 2021 11:36 pm
You may find the Lui stator lacking in power to run a brake light , better to convert to Vega spec or fit an electronic kit and loom.
Return to Luna & J Range
