J Range speedo
J Range speedo
Postby Ideal1966 » Wed Jun 10, 2020 4:50 pm
Hi all, got a J50 and want to fit a speedo to it, question is, will a J125 speedo fit in where the blanking plate is fitted or is it a different size? TIA
Ideal1966
Re: J Range speedo
Postby 57Speedster » Thu Jun 18, 2020 5:43 pm
It is the same shape & size. you will also need the speedo fitting plate, and check the 3 screws are the right length.
57Speedster
Return to Luna & J Range
