Vega leg shield
Technical help for Lui, Vega, Cometa, J50, Cento, J125, Starstream.
Vega leg shield
Postby kevinneil » Mon Oct 11, 2021 2:50 pm
Just bought a Vega and there is some damage to the left hand side leg shield. Never worked on a Lui before. Can you remove the leg shields on it to have it resprayed?
kevinneil
Re: Vega leg shield
Postby Storkfoot » Mon Oct 11, 2021 4:03 pm
Yes but you’ll have to loosen the headset and then remove the central tunnel. Despite the Vega being open frame, a lot of jobs are quite fiddly especially when they involve the central tunnel.
Re: Vega leg shield
Postby kevinneil » Mon Oct 11, 2021 4:39 pm
Mmm thought that might be the case
kevinneil
Re: Vega leg shield
Postby kevinneil » Mon Oct 11, 2021 4:42 pm
Thanks for your help. How do you remove the petrol tank?
kevinneil
Re: Vega leg shield
Postby Storkfoot » Mon Oct 11, 2021 5:55 pm
kevinneil wrote:Thanks for your help. How do you remove the petrol tank?
That’s easy :D
Take seat off, detach petrol pipe, pull it off.
Re: Vega leg shield
Postby kevinneil » Mon Oct 11, 2021 5:59 pm
Brilliant thanks
kevinneil
Return to Luna & J Range
Users browsing this forum: Baidu [Spider] and 3 guests
