I have fitted the wrong manifold, so i need to lower the front part of the engine to change it.
Do i need to remove the rear wheel to pivot the front of the engine downwards or is it best to leave the wheel fitted
HxPaul wrote:If you remove the longest stud the manifold should slide out without taking the shocker off.
