by harps2 » Mon Mar 26, 2018 2:56 pm
Hi
Almost finished total rebuild of LI 150 and want to check all wiring before starting up (as its still in conservatory) - I know you can do this by wiring up to 12V Battery charger but not sure which wires to connect - its fitted with new 12V (no battery) electronic ignition so can you please describe where I should connect to and what if anything needs disconnecting - Thanks
PS - done this before on LI 125 but that was points system - thanks again for any assistance you can offer.
harps2
by foremanbob » Mon Mar 26, 2018 4:12 pm
pull the brown loom wire from the regulator and connect that to the +ve on the battery charger...
connect the black -ve of the battery charger to the engine casing somewhere....
foremanbob
by harps2 » Wed Mar 28, 2018 8:25 am
Excellent thanks
harps2
