by Normski » Sat Mar 24, 2018 4:09 pm
Having taken the handlebar light switch apart (no dipped headlamp but main ok) to clean internal contacts, how do I re-assemble it? The little brass roller under the rocker switch defies all attempts to hold it in place until the body can be fitted. Is there a magic sequence?
Normski
by Normski » Mon Apr 09, 2018 10:05 am
Sorted! A friend placed the switch in position onto the base plate by hand and fingers pressed down against the spring pressure. Then held down by a screwdriver which had been passed through the switch aperture in the body / top cover. Slide the cover down the screwdriver and keep the two parts together by finger pressure until the screws are in position and tight. Fiddly, took a couple of tries but it works.
Normski
Users browsing this forum: Baidu [Spider] and 60 guests
