extended engine mounting
Postby holty » Tue Mar 20, 2018 9:50 pm
hi, does anyone know who can supply a quality extended engine mounting, ive had two from rayspeed made by uni and both are not made very well, the hole in the center is not central but leaning over, it puts tension on the main bar and vibrates like you wouldnt belive,
thanks in advance,
holty
holty
Re: extended engine mounting
Postby HxPaul » Tue Mar 20, 2018 10:19 pm
I use a double engine mount on the kickstart side and a SIL three hole silent block on the other side.They both use an extended engine bar,they're all supplied by AF Rayspeed and I've used them for over two years without a problem.
Postby modster79 » Wed Mar 21, 2018 9:02 am
Got mine from Andy Francis, no problems.
modster79
Postby coaster » Wed Mar 21, 2018 10:59 pm
modster79 wrote:Got mine from Andy Francis, no problems.
Same here, I think it does transmit some more vibes at certain revs but worth it with not having to change the kickstart side mount every few hundred miles/
Postby davla » Thu Mar 22, 2018 10:25 am
holty wrote:hi, does anyone know who can supply a quality extended engine mounting, ive had two from rayspeed made by uni and both are not made very well, the hole in the center is not central but leaning over, it puts tension on the main bar and vibrates like you wouldnt belive,
thanks in advance,
holty
I had the same problem with the AF extended mount, I gave them a bell and they sent me one with the hole central. It was a pain that the first one was no good but they sorted it out for me straight away. I'm still running my scooter in after an engine rebuild but the extended mount doesn't seem to create any adverse vibration.
davla
Users browsing this forum: Baidu [Spider] and 90 guests
