Lambretta '59 series 1 frame steering cone (lower)
Postby al pushpak » Sat Feb 24, 2018 9:40 pm
Hi, in the process of renewing my steering bearings & i noticed the bottom race is quite pitted so I want to replace it, does anyone know where I can purchase the correct one for my '59 series 1 from ?as they seem to vary from frame to frame. thanks for any info ;)
al pushpak
Re: Lambretta '59 series 1 frame steering cone (lower)
Postby bike grim » Sat Feb 24, 2018 10:25 pm
Scootopia
Postby ULC Soulagent » Sun Feb 25, 2018 9:48 am
bike grim wrote:Scootopia
+1
Postby al pushpak » Sun Feb 25, 2018 10:51 am
Thanks for your replies,I've looked on the scootopia website & the only ones I can find state they are not suitable for series 1 :roll: will keep searching ;)
al pushpak
Postby al pushpak » Sun Feb 25, 2018 11:12 am
Nice one ;) bike grim, cheers for that
al pushpak
Postby ULC Soulagent » Sun Feb 25, 2018 12:28 pm
Postby bike grim » Sun Feb 25, 2018 1:07 pm
No prob. Although I did get mine from Scootopia it was around 3 years ago so obvsiously not got them anymore
Postby jacktheripper » Sat Mar 03, 2018 10:47 pm
if you havnt managed to get any i have 2 x sets
jacktheripper
Postby al pushpak » Sun Mar 04, 2018 10:49 am
Thanks for the offer ;) I managed to source one from cam lam in the end, the type I needed was for the earlier series 1 which was also fitted to some ld's apparently (shorter inner sleeve) ;)
al pushpak
Postby al pushpak » Sat Mar 10, 2018 6:03 pm
Well, the search goes on! thought I'd got a new lower fame cone bearing race sorted, ordered one from camlam which stated ld / early series 1 & when it arrived the inner sleeve was about 6mm longer than my original one which measures 14mm so obviously it won't fully fit all the way in because of the lip/ridge inside the lower fork tube! does anybody know who sells the correct one for my scoot thanks for any info ;)
al pushpak
Postby HxPaul » Sat Mar 10, 2018 6:26 pm
If the length is the only difference,cant you get an engineering shop to cut the extra 1cm off.And are you sure that the length is 14cm and not 14mm,14cm is 5 1/2 inches.
Postby al pushpak » Sat Mar 10, 2018 6:34 pm
Yes, it's 14mm!! sorry maths was never my greatest subject :? so as I've stated in my previous post the one I ordered is 6mm too high, yes I guess I could have it machined down cheers
al pushpak
Postby dickie » Sat Mar 10, 2018 9:07 pm
al pushpak wrote:Yes, it's 14mm!! sorry maths was never my greatest subject :? so as I've stated in my previous post the one I ordered is 6mm too high, yes I guess I could have it machined down cheers
For something as simple as that, you could do it yourself with a decent hacksaw and a file.
Postby Phil D » Sat Mar 10, 2018 9:39 pm
This is exactly why nothing ever fits you shouldn't have to start hacksawing stuff.
Phil D
Postby dickie » Sun Mar 11, 2018 9:09 am
No, it's not "exactly why nothing ever fits" but it is a contributory factor.
Also, as the al pushpak is clearly having a bit of difficulty with this, I thought I'd use the forum to offer him a solution; which he may or may not take up.
Happy mother's day.
Postby Phil D » Sun Mar 11, 2018 10:31 am
Happy mother's day.
Thanks she passed away some years ago.
Phil D
Postby holty » Mon Mar 12, 2018 3:34 pm
hi, if its just too long i can stick it in my lathe and remove the extra length for you if your stuck, where in the country are you ?
you could post it to me ?
holty
holty
Postby al pushpak » Mon Mar 12, 2018 8:33 pm
Hi Holty, thanks very much for the offer, I've decided to order one from Rimini Lambretta which is what I should have done in the first place :? :roll: oh well , another lesson learnt! thanks again though ;)
al pushpak
