ignition switch
ignition switch
Postby stuboy » Wed Feb 14, 2018 9:48 pm
Hi can i fit an ignition switch to non battery series 3 with 12v and if so any recommendations.Thanks
stuboy
Re: ignition switch
Postby HxPaul » Wed Feb 14, 2018 11:11 pm
Yes you can,I've got two.I use Casa ignition switches,both are AC versions.
Re: ignition switch
Postby ToBoldlyGo » Thu Feb 15, 2018 12:45 am
I've got an ignition switch fitted to my LI. Although, it basically performs the same function as being a cut out switch with just the one position. But don't do what I did and think my lights had failed when I moved it to the second and third positions. I was used to riding my GP. It was then I twigged that the lights work off the handlebar switch on the LI. :oops:
Re: ignition switch
Postby HxPaul » Thu Feb 15, 2018 12:59 pm
ToBoldlyGo wrote:I've got an ignition switch fitted to my LI. Although, it basically performs the same function as being a cut out switch with just the one position. But don't do what I did and think my lights had failed when I moved it to the second and third positions. I was used to riding my GP. It was then I twigged that the lights work off the handlebar switch on the LI. :oops:
I've got a series 2 LI,I've swopped the cutout for a Casa ignition switch and use my lights from that.I've had to rewire the handlebar light switch so that it uses just the dipswitch and horn.
Re: ignition switch
Postby MK Monty » Thu Feb 15, 2018 6:27 pm
and once you have gone that far its a simple step to use the redundant switch for indicators :idea:
MK Monty
Re: ignition switch
Postby stuboy » Thu Feb 15, 2018 8:53 pm
thanks for the advice,much appreciated
stuboy
Re: ignition switch
Postby HxPaul » Thu Feb 15, 2018 10:41 pm
I hate indicators on an old Lambretta
Users browsing this forum: Baidu [Spider], Google [Bot] and 53 guests
