coaster wrote:How do you get to 190cc with a 150 barrel as a matter of interest? is it achieved by increasing the bore or stroking or both?
Cgt75b wrote:Hi Paul
I think a great basis for this conversion would be a Tv 175 barrel which would work great with the long rod.
I know you have stated you don't want to buy another barrel but that would be my route personally.
The best of luck.
CHRIS in MARGATE wrote:The barrel will bore ok. GP 150 or original TV175.
In the 60's I built a few 200's by boring out to 66mm and fitting SX200 pistons. They were thin barrel walls but they worked OK. Rafferty Newman and others offered this as a conversion rebore.
190 is less than 65mm.
Not too long ago I sold a barrel taken out to 200 and it's still out there running.
lofty wrote:definitely go for a longer rod rather than top/tail a barrel..
SR alloy barrels work very well, but need the porting fettled..
if using a cast barrel I would look for the one with the biggest transfers, and do some porting to match the manifolds, maybe open exhaust/inlet a bit (old fashioned stage 4)..
I have SR barrel, 65mm Suzuki piston, TV crank, 24mm jetex, clubman.. and its a really comfortable motor to drive and has good performance..
ToBoldlyGo wrote:I was under the impression that cast Indian barrels were particularly hard. More likely to do with the tolerances and hit and miss production. I wouldn't have thought it would be a problem if you have it bored to a good standard.
Knowledge wrote:Do any of you remember the 190 thread on the old (pre-crash) forum initiated by Little Ern? That was a classic, old-school tuning thread that taught me what little I know.
Still, nostalgia ain't what it used to be.
Storkfoot wrote:
Yes, I do remember that, also that some versions of the TS185 pistons have a ring peg over one of the ports. I’ll take the barrel with me when I buy the piston just to check
Hi Paul,
Best to go with the TS185ER pistons, as the ring pegs are further apart and therefore don't foul the inlet.
Somewhere I have some genuine NOS Suzuki pistons. I'll have a look and see if there is anything worth having at 64mm. I fear they may be over-sizes.
My current conversion of an SR barrel features a reed valve. The YPVS 350 piston and over-sizes are ideal.
Users browsing this forum: Baidu [Spider] and 43 guests
