choke set up after hot start problem fix
hello,
had hot start problem for years had suspected choke was staying on,
changed faulty fuel tap and choke plunger,problem gone,
i have set choke up and can see plunger moving up and down through hole in carb ,but when i start from cold scooter kicks up ok but doesnt race on with choke,i need to throttle, is this just a case of moving my choke up a bit,i am a bit worried i alter to much and it doesnt close off properly and i have same problem as before,assuming it was the choke that caused my hot start problem in first place,just another small thing the hole in carb where you can view your choke,the bottom of plunger is visable should it be half way up hole to be on full, just now i can see it just at bottom.........
