cylinder head cowl
cylinder head cowl
Postby WOO » Tue Jan 30, 2018 1:31 pm
I have had an upgrade from 125 to 175 with a cast iron barrel and the cyl head cowl now fouls the carbureter, does anyone know of a cowl that will fit or is it a case of altering the existing one which will require some cutting.
WOO
Re: cylinder head cowl
Postby St George » Tue Jan 30, 2018 6:25 pm
I would suggest that a 175 cowling should go straight on as the engine cases should be the same, not sure if the mag cowling will also need changing.
St George
Postby Knowledge » Tue Jan 30, 2018 6:46 pm
just grind a bit off the cowling until it clears the manifold.
Postby davla » Wed Jan 31, 2018 4:25 pm
AF Rayspeed sell good quality cowlings.....avoid SIL ones, they're actually made for Lambro three wheelers and are c***
davla
Postby martyn dwane » Fri Feb 02, 2018 2:32 pm
i believe series 1 and very early series 2 had a shorter cowling, maybe thats your problem.
martyn dwane
Users browsing this forum: Baidu [Spider], Google [Bot] and 58 guests
