by TrackTen » Sat Jan 13, 2018 2:56 pm
Hi Guys
I am replacing a Uni rear hub with one of the stronger type Scootopia ones
The threads in the Scootopia hub are onely tapped ( actual threaded part ) to 6mm deep but the Uni one is threaded 10mm deep. this means my lock washer Allen bolt bottoms out in the thread before clamping the washer - 6mm doesn’t sound like a lock for when I need to pull the bulb in the future.
Does anyone know if the 6mm depth is correct for this hub or do a I have an ‘odd’ one ?
TrackTen
by Tractorman » Sat Jan 13, 2018 5:32 pm
Just checked my new scootopia hub, 1 hole is 9.73mm and the other 2 are 12.55mm.
by TrackTen » Sat Jan 13, 2018 8:34 pm
Thanks Tractorman
I thought this didn’t seem right
A part for a Lambretta that doesn’t fit - fancy that lol
TrackTen
by gizmo » Sun Jan 14, 2018 12:25 pm
Just tried mine which I've had a while. Threads were really tight so run a tap down and now OK with around 10mm thread which I need as I have a JPP rear locking plate and the bolts need 10 mm
gizmo
Users browsing this forum: Baidu [Spider], Google [Bot] and 59 guests
