TV 200 crank case
TV 200 crank case
Postby kevinneil » Fri Jan 12, 2018 7:04 pm
I have an original TV 200 crank case that has been repaired several times and has as a result become slightly twisted. Does anyone know of a good engineering company that could have a look at the case and hopefully get it back into a working condition?
kevinneil
Re: TV 200 crank case
Postby Scooterdude » Fri Jan 12, 2018 7:38 pm
MB Scooters should be able to sort it, i took mine there for some work to be done, not got it back yet but their set up is very impressive.
Scooterdude
Postby Dazts1 » Fri Jan 12, 2018 7:50 pm
Where abouts are you ? We have a guy close to Darlington who can square off from the cylinder gasket face the other 2 faces.
I've just had the cylinder and mag flange done.
Postby kevinneil » Sat Jan 13, 2018 11:16 am
Thanks guys, I’m based in Bedfordshire. I spoke to AF Rayspeed last year who said they might have a look at it but wondered if there is anyone closer to home.
kevinneil
Users browsing this forum: Baidu [Spider], Google [Bot] and 53 guests
