original petrol tank
Postby WOO » Fri Dec 29, 2017 6:10 pm
Has anyone successfully used a tank sealant. My tank is pretty clean inside with no loose rust or particles but should i still seal it before i fit it and if so with what.
WOO
Re: original petrol tank
Postby Digger » Fri Dec 29, 2017 10:12 pm
If it's clean your "petroil" mixture will keep it that way.
Digger
Postby mr mugello » Sat Dec 30, 2017 12:32 pm
Por 15 kit is good stuff.Full kit was £50. Sort of galvanizes the inside of the tank. Used it . Seems fine. Check out YouTube for application video.
mr mugello
Postby HxPaul » Sat Dec 30, 2017 2:16 pm
Digger wrote:If it's clean your "petroil" mixture will keep it that way.
+1 I always keep it as full as possible.
Postby Storkfoot » Sat Dec 30, 2017 6:49 pm
Yes, I’d agree. As long as you have no pin hole leaks, keep it as it is.
In my experience, some tank sealants can cause more problems than they solve. Some are very good though.
Postby xenia1 » Thu Jan 04, 2018 8:35 pm
As mentioned, avoid tank sealants. What i would do is fill the tank with a mixture of phosphoric acid at 10/1 using a heavy 88% acid. Top the tank up with boiling water, leave for 30 mins, rinse and repeat. This will dissolve any remaining rust, the petroil mixture will keep it rust free..
xenia1
Postby lam1962brettagg » Sat Jan 06, 2018 10:03 pm
Hi
NEVER use tank sealant and especially never get somebody to do it for you I had somebody do it for me and completely messed my tank up took me months to sort it out if it has any rust at all use oxalic acid.
lam1962brettagg
Users browsing this forum: Baidu [Spider], Google [Bot] and 52 guests
