Small block casing info
Postby ULC Soulagent » Thu Dec 28, 2017 5:41 pm
Evening all,
Been going through my Sb casings and came across one that I picked up for £80 a few yrs ago.
It’s stamped with the number beginning *4291@@* but no model identity at the start.
It also has number stamped into the drive side engine mount arm *044063*
And finally on the inside Innocenti stamped with numbers 22 01 0061
Along with a uppercase M inside a circle :roll:
Anyone have a clue of it origins please.
Shane
Re: Small block casing info
Postby rossclark » Fri Dec 29, 2017 12:48 pm
How many ribs on the flywheel side engine mount lug?
Postby ULC Soulagent » Fri Dec 29, 2017 6:18 pm
rossclark wrote:How many ribs on the flywheel side engine mount lug?
3 central main and 2 outer ones 8-)
Postby rossclark » Fri Dec 29, 2017 7:49 pm
That makes it an Indian casing, for sure.
Postby ULC Soulagent » Sat Dec 30, 2017 4:00 am
rossclark wrote:That makes it an Indian casing, for sure.
Many thanks Rossclark ;)
Users browsing this forum: Baidu [Spider] and 43 guests
