by jonoy » Sat Aug 09, 2014 7:55 pm
my scooter is going for mot on monday
Have a problem with lights not working then they miraculously come on.
anyone help please
jonoy
by coaster » Sat Aug 09, 2014 9:21 pm
You need to carefully check through all the loom connections from the regulator through the junction box and on up to the headset, it'll be a loose bullet connector most likely. Could also be the switch.
by grandpa » Mon Aug 11, 2014 12:24 pm
Hi Jonoy,
As Coaster suggests probably bad connection but I once had intermittent blowing of fuse(D.C with battery) which turned out to be brake light switch metal plunger shorting 12 volts to ground.The internal design of (Indian) brake light switch is awful.Temporarily remove and insulate wires from brake switch if every thing else looks ok
Grandpa
grandpa
