by WOO » Fri Dec 08, 2017 6:45 pm
I have replaced all the internals of the front hub and used new fork links, no problems
As i fit the hub to the fork links the fork legs move slightly inwards as i tighten the dome nut. is this normal or should i use spacer washers to stop the fork legs moving inwards even though spacer washers are not shown in the parts book
cheers
WOO
by Wack » Fri Dec 08, 2017 9:14 pm
You could put slightly thicker washers under the hub half nuts or a wider spacer/shim inside the backplate.
Users browsing this forum: Baidu [Spider] and 37 guests
