Banjo bolt
Banjo bolt
Postby gizmo » Wed Nov 29, 2017 6:20 pm
Just got a venhill hose and fittings. The banjo bolt to the lth master cylinder is about 4mm too long as the thread in cylinder isn't deep enough. Question being. Is it OK to file a bit off length of banjo bolt.
gizmo
Re: Banjo bolt
Postby hullygully » Wed Nov 29, 2017 7:19 pm
do you have the 2 x off compression washers?
Re: Banjo bolt
Postby gizmo » Wed Nov 29, 2017 8:38 pm
hullygully wrote:do you have the 2 x off compression washers?
Yeh, got the two copper washers on but it still bottoms out. I have a hex head one which is shorter and fits but on the lth master cylinder it's a right pain as it's tight on headset bottom so the button head ones with an Allen key fitting are spot on. But are too long :(
gizmo
Re: Banjo bolt
Postby dickie » Wed Nov 29, 2017 9:16 pm
gizmo wrote:Just got a venhill hose and fittings. The banjo bolt to the lth master cylinder is about 4mm too long as the thread in cylinder isn't deep enough. Question being. Is it OK to file a bit off length of banjo bolt.
Yes
Re: Banjo bolt
Postby coaster » Wed Nov 29, 2017 10:58 pm
Readily available for a couple of pounds on ebay, not worth faffing about with imho. Just make sure you order the correct pitch
Re: Banjo bolt
Postby martyn dwane » Fri Dec 01, 2017 3:07 pm
or dump the copper crush washers and fit Dowty seals.
I had the opposite problem, with Dowty seals fitted there was only about 4 threads showing , had to use the crush washers or use my old banjo bolt, preferd the nice Venhill button head bolt.
martyn dwane
Re: Banjo bolt
Postby steve t » Fri Dec 01, 2017 9:42 pm
I would sooner see copper washers on a brake banjo just my opinion others are available. ;)
steve t
Re: Banjo bolt
Postby dickie » Fri Dec 01, 2017 10:46 pm
steve t wrote:I would sooner see copper washers on a brake banjo just my opinion others are available. ;)
Sonno di accordo
Users browsing this forum: Baidu [Spider] and 43 guests
