Fuel tank tap
Fuel tank tap
Postby andrewgc » Sun Nov 19, 2017 4:44 pm
Trying to fit a scootopia fast fuel tap to my tank but the filter won't fit up the brass tube that protrudes from the tank . Would it be ok to take the filter off and fit an in line filter between the tap and the carb?
andrewgc
Re: Fuel tank tap
Postby HxPaul » Sun Nov 19, 2017 5:18 pm
Which brass tube :?:
Re: Fuel tank tap
Postby Scooterdude » Sun Nov 19, 2017 5:33 pm
Scootopia fuel taps.....don't get me started!
Scooterdude
Re: Fuel tank tap
Postby davla » Sun Nov 19, 2017 5:38 pm
I think the brass tube that you are referring to is the filter from the original tap that you've just removed as I had the same issue recently. You need to gently pull the brass tube out with a pair of pliers and then you can fit the new tap. I had to chamfer the top of the plastic filter on the Scootopia tap very slightly for it to push into the tank, apart from that I'm really pleased with it and I like the way it clicks into the on & reserve position, I don't see what the issue is with them???
davla
Re: Fuel tank tap
Postby andrewgc » Sun Nov 19, 2017 7:18 pm
A tug with pointed pliers didn't move it , I think it's best left alone and remove the new filter???
andrewgc
Re: Fuel tank tap
Postby Storkfoot » Sun Nov 19, 2017 8:30 pm
No, you need to get it out. Is the inside of the tank badly rusted or gunged up?
Re: Fuel tank tap
Postby andrewgc » Sun Nov 19, 2017 8:45 pm
Not particularly rusted not gunged . If I really need it out I could I suppose drill it out?
andrewgc
Re: Fuel tank tap
Postby Storkfoot » Sun Nov 19, 2017 11:04 pm
I am confused. Are you saying that when you took off the old petrol tap, the internal filter part separated and is still inside the petrol tank?
Is this what you are trying to get out?
Whatever you do, be very careful about drilling and producing sparks where petrol has been.
Re: Fuel tank tap
Postby HxPaul » Mon Nov 20, 2017 12:26 am
Storkfoot wrote:I am confused. Are you saying that when you took off the old petrol tap, the internal filter part separated and is still inside the petrol tank?
And not only that,if you drill it out your going to need a filter to stop all the drillings from going into your carb.
Re: Fuel tank tap
Postby andrewgc » Mon Nov 20, 2017 12:37 am
Guys
Apologies for confusing you, I am I assure you more confused. The tank is a second hand tank I bought off fleabay and it came with a lot of rust particles inside but structurally sound.
I chucked in a load of washers and nuts and shook the hell out of it
Once i sort out this brass tube I intend to wash out with petrol before putting the tap on and installing the tank so drilling is possible or I may try a molegrips tomorrow night
andrewgc
Re: Fuel tank tap
Postby roli150lam » Mon Nov 20, 2017 7:32 am
Is it possible to push it through?.Into the tank and then out the filler neck,better than drilling if you can.
roli150lam
Re: Fuel tank tap
Postby andrewgc » Mon Nov 20, 2017 8:22 pm
good shout , i will try that first and possibly tap with a very light hammer
andrewgc
Re: Fuel tank tap
Postby Fast n Furious » Mon Nov 20, 2017 10:35 pm
A photo of this curiosity would work wonders here. ;)
Re: Fuel tank tap
Postby Phil D » Tue Nov 21, 2017 9:52 am
I often wonder why folk don't just put some pics up even if I can't help at least I'd have an idea what there on about. :lol:
Phil D
Re: Fuel tank tap
Postby Rich Oswald » Tue Nov 21, 2017 12:10 pm
Phil D wrote:I often wonder why folk don't just put some pics up even if I can't help at least I'd have an idea what there on about. :lol:
That's easier said than done Phil' ;)
Re: Fuel tank tap
Postby CHRIS in MARGATE » Tue Nov 21, 2017 12:21 pm
Sorry I am lost.
Re: Fuel tank tap
Postby Storkfoot » Tue Nov 21, 2017 3:13 pm
I am going to have a guess :)
I reckon you’ll find it is part of the petrol tap. I also reckon you’ll discover that the inside of your tank is in a lot worse condition than you think. I suspect it is a combination of sediment, rust and gunge that is holding it in place.
Please don’t keep us in suspense too long :D
Re: Fuel tank tap
Postby andrewgc » Tue Nov 21, 2017 6:31 pm
guys
been doing my CbT in the pi55ing down rain and wind today so i am cream crackered , when i get a chance i will give it another go and update you all. As for pictures i have tried but keep getting response file too big- again work in progress
andrewgc
Re: Fuel tank tap
Postby andrewgc » Sun Nov 26, 2017 7:11 pm
Good news its out :):)
what i did is spray it with a bit of wd40 this morning and left it until this evening i then fed a wooden dowel down the tube so that i could secure it with a mole grips ie making it a solid item that wouldnt simply implode , three twists and out she came !!
it must have been the original filter as the tube that was inside the tank had a series of holes to allow the fuel through but not any particles.
now to give the tank a damb good clean inside - any tips??
andrewgc
Re: Fuel tank tap
Postby Storkfoot » Sun Nov 26, 2017 10:34 pm
Glad you got it out. It must need a proper clean inside.
I have done 4 tanks following this link. Be careful when doing it but it works miles better than any other method I have ever tried
http://www.realclassic.co.uk/techfiles/ ... moval.html
Users browsing this forum: Baidu [Spider] and 39 guests
