Rear brake cable routing
Did I see a post sometime ago regarding the routing of the rear brake cable that said it should go between the plug and the frame? I tried routing this way but it seems to be very close to the plug cap.
https://ilambretta.co.uk/forum/
coaster wrote:I believe that is correct but whatever you do, don't route it over the top of the engine mount, I did that and it worked fine until I loaded up for Adria and found that the brake was pulling on
Strangely, that detail has been missed in both versions of Sticky's book
dickie wrote:I think the rebuild blog on lcgb home page by Paul slack covers this.
Tractorman wrote:dickie wrote:I think the rebuild blog on lcgb home page by Paul slack covers this.
I searched through it but could not find it, where is it, please?
Tractorman wrote:Did I see a post sometime ago regarding the routing of the rear brake cable that said it should go between the plug and the frame? I tried routing this way but it seems to be very close to the plug cap.
Danbretta wrote:My import came with this routing (if it helps).
Seems to be ok not sure if it's the correct way.
