Delboyli150 wrote:.....................The only thing I can think to this is in certain configurations the LED stays on, but the SIP is flashing Fuel so I would have thought the LED would flash as well.
Delboyli150 wrote:.....Coaster, The solid light came on when the tank was full!, I could understand if when the SIP flashed then the LED came on solid that would be great! and exactly what I am after, but this is not happening.
Delboyli150 wrote:Ah Cheers Coaster, looks like a winter project!
I can see the logic but was hoping for a simpler way! Going down this route I would be concerned that the relay would vibrate too easily and break. If you do go down the transistor route can you let me know how you got on?
Or does anyone else on here can come up with a simpler route?
