6V Ducati Points Coil
Postby TurboTrev » Wed Oct 18, 2017 3:54 pm
Is there any way of checking that an old original 6v Ducati Points Coil is working without attaching it to a scooter and wiring it in? Thanks.
TurboTrev
Re: 6V Ducati Points Coil
Postby Chadley » Wed Oct 18, 2017 11:41 pm
Measure resistance between terminals labelled '1' and '15'. Should be less than 0.5 Ohm. Resistance between terminal '1' and HT output as well as terminal '15' and HT output should be around 10-12 KOhm. That's no proof that coil is okay but rules out some types of failure.
Chadley
Postby Fast n Furious » Thu Oct 19, 2017 12:45 am
Unfortunately there is no easy on the bench way to confirm operation of an HT coil without some proper testing kit.
Coils do degrade with time through insulation breakdown.
If you have any reason to doubt an aged coil then a new replacement is the best course of action.
Beware of Chinese made coils. They really are garbage. :(
Postby TurboTrev » Thu Oct 19, 2017 10:30 am
^^Many thanks for your answers/guidance.
TurboTrev
Users browsing this forum: dave81 and 65 guests
